Moser 9" ABS/Low Trac problems
Old Feb 21, 2005 | 07:14 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Default Moser 9" ABS/Low Trac problems
Test drove the car today and found that the ABS is coming on at the tap of the brake pedal. The low trac light is also coming on. We scanned the mph of each wheel while driving and found that the left rear sensor is a couple mph off. I've read a few posts which say that the studs on Moser setups interfere with the ABS sensors- therefore requiring shims. Is this my problem? We'll try shimming tomorrow to see if this works, if not, I'm having ABS deleted.
This Moser 9" install has really been a test of patience.
Old Feb 21, 2005 | 10:30 PM
44mag's Avatar
MAN!!!!!! you've had nothing but problems with the install. hope mine goes in easier!!!!!!!!! keep patient you'll get right eventually!
Old Feb 21, 2005 | 11:14 PM
Elite_Hot_Rod's Avatar
My Moser 12 bolt did the same thing, first I changed the sensors side to side no luck. Then I shimmed out the D/S speed sensor, no luck. Then I replaced it with the same results. I was changing out the rear pads and noticed that several of the D/S wheel studs had backed out and 1 was rubbing against the axle slowing that side just enough for the sensors to pick it up. Check and see if all of your studs are good and tight. Cheap fix.
Old Feb 22, 2005 | 12:32 AM
!LS1 11 Second Club
Great info. Thanks!
Old Feb 22, 2005 | 12:25 PM
!LS1 11 Second Club
1/4" Shims did the trick.
Old Feb 22, 2005 | 01:02 PM
1/4 is awefully thich shims, that would pull the wheel speed sensor completely away from the gear. I would tend to think something else is wrong.
Old Feb 22, 2005 | 01:08 PM
!LS1 11 Second Club
True, the sensor could be clear of the teeth now, but a wheel mph scan will confirm that for us. Thanks for the concern!
Old Feb 23, 2005 | 12:40 PM
!LS1 11 Second Club
Shimming seemed to have worked temporarily, but ABS INOP just triggered after a few miles of driving. Haven't scanned the wheel MPH yet. The sensors may very well be clear of the teeth now.
Old Feb 23, 2005 | 04:39 PM
1QWIKZ's Avatar
i say FUG the ABS....
Old Feb 23, 2005 | 05:59 PM
LTFOUR's Avatar
I wouldn't even consider ABS...
Old Feb 23, 2005 | 09:34 PM
Mine did the same thing when I shimmed it out, worked for alittle while then the light back came on. Check those studs and see if they backed out. Once I tightened them back down and used Loctite it went away for good.
Old Feb 24, 2005 | 11:48 AM
!LS1 11 Second Club
Thanks for all the responses....
I've purchased the SJM ABS delete kit.
To quote 1QWIKZ:
Old Feb 24, 2005 | 01:58 PM
1QWIKZ's Avatar
To quote 1QWIKZ:
Old Feb 24, 2005 | 04:01 PM
cyphur's Avatar
i installed a moser 9" last weekend and since i have a 3ch car.....no ABS for me. might as well benefit from the weight reduction of those components, where'd you find this SJM !ABS kit SouthFL? Only setup I've run across is the kit @ Billingsley Racing.
Old Feb 24, 2005 | 04:07 PM
!LS1 11 Second Club
http://www.mycamaroz28.homestead.com/
They used to have a banner over here----->
