Moser 12bolt, I need HELP!
Old Nov 17, 2001 | 10:45 AM
nitropickup's Avatar
Default Moser 12bolt, I need HELP!
I'm installing a Moser 12bolt in a 6spd car. Does anybody know the part # for the universal joint?
Old Nov 18, 2001 | 01:27 PM
MIGHTYMOUSE's Avatar
Default Re: Moser 12bolt, I need HELP!
i got mine from napa.. if you have the stock driveshaft, get the spicer for the 1350 i think.. but do a search on the other ls1com to find for sure.
Old Nov 19, 2001 | 05:04 PM
AZLS1's Avatar
Good luck on getting the right answer you will need it and if you get the right one it may have been by luck.
This was my experience.
I bought 4 u-joints based on recomendations from the board (I figured that I would just take the 3 back that didn't fit.)
It turned out that for my application I needed a different u-joint than any of the four that were suggested. When I went to the machine shop to have the old one pressed out and the new one pressed in and to have the new rings pressed onto the axle, I had the guy measure and tell me which one I needed.
It would have saved me alot of trouble if I had just had the machine shop guy measure the bearing caps from the start.
Sterling.
<img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
