How hot is your rear?
upgrade.Then they require a shorter shaft.When the sell us these $2200 rear ends it
would be nice if they informed us of that.Gomer the local cut job on the shaft is most likely the vibration issue.If they set up the rear with a solid pinion spacer they probably
got the pinion preload a bit on the tight side which would cause the heat issue.
