Rear End Question
Old Feb 23, 2005 | 01:11 PM
KBOBOZ71's Avatar
Default Rear End Question
I Am Fixing To Buy Some Parts For My Rear End I Have A Gm 10 7.5" Ring Gear 26 Spline. Should I Try To Weld The Spiper Gears Or Put A Mini Spool In It. I Will Be Running About 400 Rwhp And 400 Lbtq. What Would Hold Up Better? Thanks In Advance.
Old Feb 23, 2005 | 03:31 PM
technical's Avatar
Neither if you plan on running sticky's/slicks and hitting the track.
Old Feb 23, 2005 | 04:11 PM
stroked 68's Avatar
i could never get the weld to hold. it always snaped the first turn i made with good tires. i would go with a moser 9" haha!
Old Feb 23, 2005 | 04:29 PM
Smitty's Avatar
A4 or M6? I would swap from the torsen to a eaton,moser axles,motive gears,carrier bearing cap studs,and a good rear cover(T/A).Sticking tires and a 7.5 just do not mix,sooner more so than later with a M6.If you needed more than that,I'd just spring for the 12 bolt or 9 inch.
Old Feb 25, 2005 | 07:30 AM
KBOBOZ71's Avatar
THANKS!
