Could the Billingsley Fabbed 9 be built for less?
Originally Posted by Hawkcmc
Do we know what ring we should use for the pinion mount? I have been trying to figure out what ring to buy to set that up. We cant use the stock ring can we? Do you have to buy a torque arm? The stock one wont work ?
Thanks again guys,
CMC
Thanks again guys,
CMC
The reluctor ring for the 3 channel abs is on the carrier.
I have heard of a few people making one to work on a 9inch.
I have never looked into it. I don't miss my ABS. Just need to pull the bulb out of the dash to turn off that annoying *** light lol.
Brad
Brad
ok guys any idea where a good idea to get the housing and axles are? I will probably try Speed Inc. but any other suggestions are appreciated. Also do i have to press any bearings and such or should the bolt in housing have them installed already, i am assuming the center section shouldnt need anything but to slide the axles in right?
Thanks again for the good info guys.
CMC
CMC
