Do I NEED lca brackets and an adj. PHR?
Thanks,
Justin
<strong>My car is lowered, I have a 12 bolt, and BMR lca's, otherwise suspension is stock. Do I need relocation brackets to get an optimal pinion angle? If so, what is the optimal pinion angle? Is an adj PHR necessary to center the rear when I put my 12bolt in tommorow? Race on the 8th, really don't have the money to buy them, but if its critical I will.
Thanks,
Justin</strong><hr></blockquote>
Justin no more power then my car makes once I lowered my car I installed BMR relocating brackets..I used the bottom holes on the brackets..
I also installed a Randomtech torque arm with the pinion angle set at -2.5 degree's..I talked to several people who've told me for the street you don't want no more angle then that because of U joint failure..
I picked up almost a 10th and 2mph with just the suspension mods once I had them done...
