1350 Pinion yoke
Old Mar 20, 2005 | 12:55 PM
EATAZ06MMM's Avatar
Default 1350 Pinion yoke
I am getting ready to replace my drive shaft w/ one that has 1350 u-bolts.
My question is: how do I tell if the pinion yoke that is on a 12-bolt KTRE rearend a 1350 or not?
Also, does the pinion yoke press on? Or does it just slide off?
Thanks
Old Mar 21, 2005 | 01:11 AM
TheBlurLS1's Avatar
That's what she said...
you can go to napa and get a u-joint part number 447 and see if the slightly larger (1350) side fits the KTRE. the stock and the 1350 are almost the same (you'd be suprised how close).
do you already have the KTRE? if not you can definatly order it on there when you order it.
pinion yoke's are splined, slid onto the pinion, and held on by a nut screwed on the end of the pinion. it is tightened to a very precise in/lbs and is critical for reducing gear whine and proper alignment.
Old Mar 21, 2005 | 12:37 PM
EATAZ06MMM's Avatar
Thanks for the insight. Yep, already have a KTRE. I bought the car with the KTRE already installed. Just trying to figure out exactly what I have. I've heard mixed reviews on the KTRE. Mostly bad, but I guess I'll see how it goes...
I need to buy a heavy duty driveshaft because I still have the stock aluminum driveshaft which is why I'm trying to verify the pinion yoke.
Thanks for the help
Old Mar 22, 2005 | 01:55 AM
TheBlurLS1's Avatar
oh yeah, you can bring the u-joint back to napa dont forget that part lol
pull that driveshaft off and compare it to the 447 u-joint. what other mods do you have? the aluminum driveshafts usually hold up pretty well to bolton/cam only cars.
Old Sep 16, 2005 | 10:46 AM
SSnakekiller's Avatar
Actual Part# is not 447, it is 2400447. This is the 1310 (stock ds) to 1350 u-joint.
Old Sep 16, 2005 | 05:29 PM
Hawkcmc's Avatar
Measure the journals, or the part that the cups go into on your 12 bolt. If they are 1 3/16" then its a 1350.
CMC
