Pro Gears overkill??
Old Mar 21, 2005 | 06:43 PM
CanuckSS's Avatar
Default Pro Gears overkill??
Hey Guys,
I am in the process of building a 9 inch and was curious what you guys would recommend for gears. Do you think pro gears (35 spline pinion) are overkill for a M6 that will probably never see any more that 500hp (in the future), or do you think a normal 28 spline pinion would be sufficient?
If it matters I will be using the strange aluminum 3rd member.
Thanks in advance,
Dave Hounsell
Old Mar 21, 2005 | 07:17 PM
PHIL H's Avatar
For a race car the pro gears are ok, but a street car that will see any miles at all the gears will wear out real fast. Pro gears are made of softer alloy to absorb shock. They get the job done, but not street car friendly.
Phil
Old Mar 21, 2005 | 09:34 PM
CanuckSS's Avatar
So buying a set of used pro gears would be foolish I guess?
Old Mar 21, 2005 | 11:37 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
yup, they won't get you more than 10 miles before they melt down.
Old Mar 22, 2005 | 07:12 AM
CanuckSS's Avatar
Will a 28 spline pinion stand up to high RPM launches?
Old Mar 22, 2005 | 08:37 AM
mzoomora's Avatar
14 Second Truck Club
You can run single digit ET's with a street gear, we have customers that do it regularly with 9" stuff. Your chances of breaking it due to shock load are greater, but they live pretty well. You can drive a pro gear on the street also, but you would be looking at a new gear every year or so depending on driving conditions, highway miles are harder on them.
