will it work?
Old Apr 7, 2005 | 08:36 PM
SMAX's Avatar
Default will it work?
can i put a rearend out of a 94 camaro in my 2000?
Old Apr 7, 2005 | 09:03 PM
PRAY HRD's Avatar
yes, but you'll have an issue with the abs. your '94 has a 3 channel setup and your '00 was setup for a 4 channel. otherwise, the dimensions are the same as well as all the hookups and suspension bracket mounting points.
Dave
Old Apr 8, 2005 | 03:24 AM
SMAX's Avatar
my 2000 doesnt have traction control so that means it is a 3 channel right? which means i will not have problems with the abs right?
