Piecing together a 12bolt?
Old Apr 8, 2005 | 05:12 PM
Valkyn's Avatar
Default Piecing together a 12bolt?
Was looking around on here and found this:
12 Bolt - F-Body and Coil Spring Rear
12 Bolt Housing & Axle Package $1295
(Includes 12 Bolt Housing with brackets, M/E Custom Alloy Axles, new housing ends, wheel bearings, wheel studs, retainer plates)
Was curious if you had this what else would be required to have a complete rear? I know you would need a posi unit/spool and a pinion yoke.
What would you have to do to retain 3 channel ABS?
Old Apr 8, 2005 | 05:38 PM
WS6WRX's Avatar
You will need a 3 chan diff carrier(the reluctor gear is mounted on it), a posi/locker/spool, a ring/pinion and the applicable installation kit. Theoretically the center section should have the mounting hole for the ABS sensor, but you may need a 12 bolt specific one.
Old Apr 8, 2005 | 06:03 PM
Valkyn's Avatar
How much does a 3 channel carrier cost?
