C-clip removle question
Old Apr 12, 2005 | 09:07 PM
DMcRacer's Avatar
Default C-clip removle question
I've been trying to get these motherfreakers out for about an hour now. The last time I worked on my old LT1, I removed the retaining block, shoved the axles in and the C clips came right out.
I cant get them to clear the spiders gears. Is there a trick I dont know about?
Is this an indication of a problem some where ?
Old Apr 12, 2005 | 09:18 PM
rstmeredZ's Avatar
I just did mine 2 days ago. If needle nose doesn't work, then use a magnet.
Old Apr 12, 2005 | 09:21 PM
DMcRacer's Avatar
I've been tryng a magnet. I think I'll have my son hold in on the axle while I try. I used a C clamp to hold it in, that may have angled the axle to one side or something.
Old Apr 12, 2005 | 09:37 PM
DMcRacer's Avatar
I got it, Just had to sqeeze the axles in a little more than I was comfortable with.
Old Apr 12, 2005 | 11:56 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Does your car a 4 chanel ABS? you need to use a 10mm wrench and back off the sensors a little for extra clearence.
