How many quarts?
Old Apr 25, 2005 | 07:55 PM
RedWS601's Avatar
Default How many quarts?
How many quarts of gear oil does the differential take ona 2001 TA (stock)? I put in one quart then gear additive and then putting in the second quart most of it came out? Someone clarify how much I need and why did the oil come out?
Old Apr 25, 2005 | 09:03 PM
Krab's Avatar
It should take almost all of the second quart if your car is leveled. It should start pouring out of the fill hole once you're at about the last 1/4 of the quart.
Old Apr 25, 2005 | 10:31 PM
ace68's Avatar
I would check again in a day make sure you get it filled, some will go into the axel tube.
Old Apr 25, 2005 | 11:47 PM
LS1MONSTER's Avatar
I just keep pumping until it starts to come out.. and I never really know how much it takes since I have to refill the bottle and pump in more fluid till I'm done. Best bet would to check after a good drive.
Old Apr 26, 2005 | 06:44 AM
peterock98's Avatar
Fill to over flow.
Old Apr 26, 2005 | 09:22 AM
ace68's Avatar
Fill to overflow is correct however, if you put it in too fast the oil is so thick it gathers near the center section and doesn't flow everywhere. Therefore, in about a hour you'll be low and you could burn some **** up possibly. I just like to make sure with my stuff ya know.
Old Apr 26, 2005 | 09:42 AM
peterock98's Avatar
Your right better to be safe.
Old Apr 26, 2005 | 10:16 AM
SStheBest's Avatar
Fill to over flow.
i guaruntee u do this....and ur bound to blow ur seal around the sensor....if u dont believe me continue to do this and look under ur rear and u will see to what appears look like a leak....if u over low it it WILL come back out...and not the way it went in...
Old Apr 26, 2005 | 11:09 AM
ace68's Avatar
That's why I do it the slow way and when it starts dripping out I'm done.
Make sure the car is on level ground of cores.
Old Apr 26, 2005 | 02:52 PM
soldeir's Avatar
