What to do for rear end?
Anyways here goes....I guess it all depends in what you are going to do with the car. If it is going to be a daily driver, which I think it is in your case, you have to ask yourself : Do I want my car to be broken all of the time? Am I constantly going to go to the drag strip and use the nitrous? Am I going to be using slicks? I seen in another forum that you were asking about suspension uprgades, how much traction do you think you are going to be getting. With all of these questions asked and relizing you might have enough power to brake the stock 10 bolt, how much money do you want to spend if you can break it. Most people go with a 12 bolt rear or a Ford 9" made for our cars. Moser makes a good one. Those are form 2000-2500 bucks. You could also do a TA rearend girdle for your stock 10 bolt for a little less money.
Loudmouth exhaust, LS6 intake, ram air hood, other minor bolt ons, c5s, than go to a top of the line 150 shot nitrous set up. than some shocks and lowering springs and minor weight reduction, not sure where from there unless new gears gears would help too. I am very new t this and no very little so all input is GREATLY appreciated.
