auburn or torsen?
Old May 4, 2005 | 10:30 PM
frogger13's Avatar
Default auburn or torsen?
how can i find out if i have a auburn or torsen?just wondering cause i dont know the difference.Its a 99 ss.thanks in advance!
Old May 5, 2005 | 10:09 AM
SSCamaro99_3's Avatar
It should say on the SLP door tag. You can also call SLP.
Old May 5, 2005 | 12:57 PM
WS6HUMMER's Avatar
I thought the Torsions have no clutches and the Auburn have clutches like a regular LSD. Also the Auburns have a regular style pin that goes through a set of spider gears while the Torsion carrier has a block that slips in the center instead of a conventional drop in pin.
Old May 5, 2005 | 04:30 PM
LS1LT1's Avatar
I think '99 was the first year the Torsen diff was standard (I know all '00s had them) but the Auburn was an option as well I think.
Old May 5, 2005 | 10:08 PM
frogger13's Avatar
I dont have a slp tag or options .Its a hardtop w/cloth interior,no tcs,no slp lid.If i pull the diff. cover how can i tell the difference?Also how can i tell the difference between 3 channel and 4 channel abs?I want to switch to a 12 bolt before i start other mods.
Old May 6, 2005 | 08:13 AM
WS6HUMMER's Avatar
If you have TCS it's usually 4 channel and if not it's 3 channel. Also, 4 channel cars have exciter rings pressed onto the axles just behind the stud plate, you can see it without pulling the axle if you pull one of the rear rotors. 3 channel cars have a much bigger exciter ring in the center section right beside the ring gear.
