Trans fluid leaking from bellhousing!!
Old Dec 20, 2001 | 10:59 AM
Sears's Avatar
!Dial-up Director
Default Trans fluid leaking from bellhousing!!
http://justin98ta.cz28.com/leak
I woke up this morning to see a quart of transmission fluid on the carport. <img src="gr_eek2.gif" border="0"> It's dripping out the flywheel inspection hole. Is there a seal on the input shaft that might be busted? I just had my tranny serviced too.
What to do?
<img src="images/icons/confused.gif" border="0">
[ December 20, 2001: Message edited by: Jsears8 ]</p>
Old Dec 20, 2001 | 11:12 AM
Dave Carney's Avatar
Default Re: Trans fluid leaking from bellhousing!!
Did they overfill it?? Did they pressure flush it and somehow blow out that front seal I wonder?
Old Dec 20, 2001 | 04:31 PM
DR.BOOST's Avatar
It is possible its leaking from the front pump seal. What kind of service was done to the trans?
Old Dec 20, 2001 | 04:34 PM
Black LS1 T/A's Avatar
Moderator
When that happened to me, my pump was toast (bearing gone).
Since you just had it serviced, I'd take it back to them pronto... it's possible they did something.
Old Dec 20, 2001 | 06:32 PM
Sears's Avatar
!Dial-up Director
What pump? It's a T-56 not an auto. A couple of synchro buttons and slider were replaced.
Old Dec 20, 2001 | 06:56 PM
wizkid's Avatar
Install Director
Leaky slave?
Eric
Old Dec 20, 2001 | 06:58 PM
Sears's Avatar
!Dial-up Director
It's trans fluid. <img src="gr_stretch.gif" border="0">
There is a drain plug below the input shaft that I am going to check, if it's not that then I guess it's the seal. <img src="gr_sad.gif" border="0">
Old Dec 21, 2001 | 11:02 PM
Sears's Avatar
!Dial-up Director
Pulled it out tonight and it's leaking from the front seal! <img src="gr_images/icons/mad.gif" border="0"> This is the second fu(kin$ time I've had to pull it out after getting it rebuilt! <img src="gr_images/icons/mad.gif" border="0"> What a bunch of.. <img src="graemlins/gr_bs.gif" border="0" alt="[bullshit]" />
<img src="graemlins/gr_guns.gif" border="0" alt="[guns]" /> <img src="graemlins/gr_punch.gif" border="0" alt="[fight]" /> <img src="gr_images/icons/mad.gif" border="0">
Old Dec 22, 2001 | 01:44 AM
Jason99T/A's Avatar
I can shift faster than you.
That sucks Justin.... <img src="gr_sad.gif" border="0">
