Whee Fitment. 2000 Camaro
Old Dec 21, 2001 | 12:24 AM
Psycho Dave's Avatar
Default Whee Fitment. 2000 Camaro
I was wondering if anyone is running a 15x3.5 and 15x8 on their car? I would like to run a 15" wheel but I am not sure if it will clear the disc brakes. If anyone has 15" wheels can you give me a brand name, model name and back spacing? Thanks in advance for the help.
-Dave
Old Dec 21, 2001 | 12:50 AM
DravenMyers's Avatar
Default Re: Whee Fitment. 2000 Camaro
I have Weld Draglites and i'm running 15x3.5's, bolt circle 5x4.5/4.75 with 1.75 back spacing, upfront. On the back i'm running 15x8's, bolt circle 5x4.5/4.75 with 5.5 back spacing. Your front calipers will not need grinding, but you will need 5/16in wheel spacers. For the back, you can either put 5/16in wheel spacers and grind your caliper or go with no wheel spacers and grind a lot more. If you don't mind your tires sticking out a bit, then go with the spacers(it's not that bad). Hope this helps <img src="gr_stretch.gif" border="0">
