Pics of a rearend... HELP please
Old May 9, 2005 | 01:15 AM
sfriesen's Avatar
Default Pics of a rearend... HELP please
Obviously a 4th Gen F-body housing, I have looked and it is 3.43 gearing. My question is, is that plug in connector at the top for the Traction control or what? If I were to clean this thing up and replace my 3.23's that are under my 98 T/A with a 6-speed in it, would the difference from the 3.23 to the 3.43 be worth it?
Old May 9, 2005 | 07:36 AM
RaNsOm's Avatar
plug on th etop is the ABS sensor. The car this rear came out of was not equipped with TCS.
Old May 9, 2005 | 08:22 AM
sfriesen's Avatar
OK cool, so I shouldn't have any problems swapping it into my 98 then right?
Old May 9, 2005 | 09:08 AM
86irocz's Avatar
No, all you have to do is swap out your axleshafts and backing plates. The 4 chanel will work out fine.
