Rearend/Sups. Problem
Old May 10, 2005 | 05:50 PM
mattr228's Avatar
Default Rearend/Susp. Problem
i have a 99 Camaro SS A4 with a Yank SS3600 , bilstein shocks , suspension techniques anti-roll bar , stock LCAs & stock PHB , as well as SLP Sub-Frame connecters....
i took my car to the track in early april to see what it would do on the M/T Drag Radials .... after many 1.75 60's I noticed a little popping sound the car would make on the street. This popping noise would only occur under mild & hard acceleration but never easing into the throttle. Also it would do the same popping sound when the car came to a complete stop. But that my be the least of my problems
Today driving back and forth from school i noticed that the right rear wheel gave me a feeling that something was disconnected from it. And resulting in a "wobbling" sound going over bumps & dips in the road. I checked the shocks, sway bar end links , lugnuts, LCAs & PHB for any lose bolts , nuts , you name it. And it all checked out fine.
What & were could this be coming from? ANy info is greatly appreciated.
-Matt
Old May 10, 2005 | 09:32 PM
86irocz's Avatar
A bad axle bearing would cause that, has the car ever been in any accidents?
