Need Help Please!
Old May 16, 2005 | 11:47 PM
99hugcam's Avatar
Question Need Help Please!
Ok, took out my stock rear, took it to work and installed strange 4.10 set. Great contact pattern and backlash and what not. After painting the rear I started putting everything back together. Go to put the axles back in and the (don't know the name of it?) block that you have to remove to get the c-clips out is sliding out but now is hitting the ring gear??? Anyone had this happen? It is just barely hitting. Please someone help!!!
Old May 17, 2005 | 11:16 AM
~JOSHUA's Avatar
Can you just grind a little on the block? Some people grind the gears, some grind the block.
Hope this helps.
Old May 17, 2005 | 01:58 PM
HBHRacing's Avatar
either order the 2 pice set from SLP, or just grind enough for clearence. it's common.
