Another need help quick w/9" problem!
Old May 25, 2005 | 10:07 AM
SStillSSmokin's Avatar
Default Another need help quick w/9" problem!
Hey guys, I bought a used Moser 9" "bolt in rear which is having bearings/exiter rings switched from my 10 bolt right now.
My mechanic just called and said that the exiter rings from my rear will not fit on the 9" axles! I have the 4 ch. rear, the 9" may have been from a LT1 car, I'm not sure. He said the I.D. of the rings is around 2.830" and the part on the axle where it should go is 2.200" O.D.
Is there any way to make this work? He could have it done today if we can get this figured out. Or would I either have to run w/out ABS/ASR, or get new axles?
Thanks for any help you can give!!!!
Old May 25, 2005 | 09:10 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Moser makes their own and the axle might be machined for theirs. Call Moser and find out 260-726-6689.
Old May 26, 2005 | 09:08 AM
THANKS! Called them and yeah, they make an adapter(bushing) that gets pressed onto the 2.200" part of the axle then the ring gets pressed onto that. That's alot of pressing!
$100 plus 13.91 shipping and they will be here Tues.
