Guys with Hotchkis subframes connectors>>>>>>>
Mike-Z
<strong>On ls1's its easiest if you cut the drivers side subframe at the very front. Its the point where the subframe makes a "|_|" from the side view. You want to cut the front portion of this "|_|" off, making the subframe connector look like a "_|" This is when viewing the subframe connector as it will be installed from the drivers side of the car. The should be it. Hotchiks does recommend you move the fuel lines in the INTRUCTIONS, so i suggest you find a welder who is literate.</strong><hr></blockquote>
