Poly Tranny mount question...
Thanks,
Kevin
First off, do not use that damn pre-load plate. When I installed my mount the first time with that plate, it almost rattled my teeth out. Taking that off stopped about 90% of the vibes. I proceded to grind down the 2 "knubs" on the belly of the mount...basically making it a flat surface so it would sit flush on the car. I also did not use any washers. Everything works great, and I have no extra vibrations to speak of. Hope this helps....
Josh
I may try to install fender washers between the cross member. Thanks guys.
Kevin
