Diffrential Oil change?
Old Jun 27, 2005 | 08:30 PM
yekta's Avatar
Question Diffrential Oil change?
It says 37500 miles is the time to change your diffrential oil in manual. Did you guys change it? is it important? what kinda oil would u suggest? Do I need to know some tricks before I get under the car?
Old Jun 27, 2005 | 08:44 PM
Ferocity02's Avatar
I changed mine. It's worth it IMO. I used Red Line 75w90. You need to unbolt the diff cover to drain the fluid. Buy a new cover gasket and then bolt the cover back on. Pull out the plug on the side and fill up until oil starts coming out, about two quarts.
Old Jun 27, 2005 | 09:03 PM
yekta's Avatar
Thanx a lot man
Old Jun 27, 2005 | 10:35 PM
GreekGator's Avatar
so what are other good gear oils to use. what weight is optimal to use. i know that the 75w90 is recommended. What is the other weight that is available for use and why is 75w90 recommended? also, i have a MAC differential cover. should i get rtv sealant when i go to put it on and use allen bolts? TIA
Old Jun 28, 2005 | 08:24 AM
Mr Incredible's Avatar
Here's a relevant thread: Thread
Old Jun 28, 2005 | 11:59 AM
GreekGator's Avatar
what else would i need to install my MAC differential cover???also, why is 75w90 gear oil the optimal choice as far as weights go?
Old Jun 28, 2005 | 01:00 PM
Steve Burger's Avatar
LS1TECH Sponsor
I change mine at least once a year with Valvoline 85 - 140 and 2 bottles of LSA from GM. I do have a Moser 12 bolt and race quite a bit.
