12 bolt issue with Autocross use.
At a recent autocross that was run clockwise (mostly right turns) the tube spilled out some axle lube. I assume some of the prolonged sweepers push the oil up the tube. What can be done to prevent this, possibly an pcv valve or some sort of a catch can. I was thinking the valve would close when oil hit it but would allow expanding gases to escape..
Thank you for your input in advance.
Rampant
My 87 GMC truck has long breather tube going from the rear up to the frame with one of those plastic vents held in place with a hose clamp. Maybe you could snag one at a junk yard off a truck.
Thanks!
Rampant
