how about 10bolt 8.5
because the 10 bolt 8.5 is bigger, I was daydreaming of puting the center of the big 10b (aparently is a limited slip, a lot of mechanical centrifugaly driven levers) with the sleeves for the axles from my camaro, custom axles, and custom yoke.
also to hold the central torque arm I plan to make a welded structure of 3/8 plate bolted to the rear bolt cover.
what do you think?
Ive heard a comment that about two years in the truck magazien came this swap (that was for a s10 btw)
the objectibe is to have a little stronger rear end CHEAPPPPPP!!!!!!
I was going to try to fab an 8.5'' out of a truck to fit my car by welding my stock axle tubes to its center section a few inches out, then fabbing a torque arm bracket. But when i started to figure everything up, i was going to spend around $800 just on the axles, gears and carrier. That was before i had bought the rear itself or payed to have the torque arm mount welded on.
All in all i thought it was too risky to spend $1000+ on.
But if you had rear with a good posi and gear set already, it could be a different story for you.
In regard to the torque arm, originally the freebie rear end housings was for me to experiment with welding in cast iron, to see how the weld might behave in term of permament distortion, alignment, and general strength of the whole thing....
but my best solution will be to bolt a Flange before or after, the RE cover, and then some structure welded to the flange and around the axles to the actual torque arm.
then 4.10 all the way!!!!!
