rear end question..
Old Aug 3, 2005 | 09:54 PM
NikonDrgn's Avatar
Default rear end question..
looking into getting a new rear (axle, diff, gears, everything...) and was curious how hard it would be to put a stock rear from a 4-channel 01 TA into an 00 Formula without traction control..
Old Aug 4, 2005 | 07:23 AM
Blacker's Avatar
It will bolt up fine. You will need the brake lines from the 3 channel rearend. Also, the ABS will no longer be functional.
Old Aug 4, 2005 | 12:57 PM
NikonDrgn's Avatar
no easy way to wire it up and keep the ABS then?
guess it's time to try and find a 3-channel..
thanks for the info
