posi question
Old Jan 22, 2002 | 05:22 PM
restoman45's Avatar
Default posi question
can someone please explain the pros and cons and intended uses for all types of posi's (like whats best for drag racing or road racing). for example the detroit locker, eatons and auborns design, and spyder gears, etc. thanks very much. <img src="gr_images/icons/cool.gif" border="0">
Old Feb 4, 2002 | 04:36 PM
2000 Camaro SS's Avatar
Default Re: posi question
TTT
Trying to help ya out
Old Feb 5, 2002 | 09:39 AM
Bad30th's Avatar
Wow, that's a lot of stuff for one post ! <img src="gr_tounge.gif" border="0">
I'll chime in with what I know, not that I know that much :
The Eaton posi is a true "positrac" system, always turning both rear wheels at equal speeds.
The Torsen uses a torque sensing differential - when one wheel turns at 70%, the other wheel turns at 30%. Not true equal distribution of power. The Torsen uses internal spider gears.
The GM stock Auburn rear uses a clutch/disc system and is (from what I understand) the weakest of the three.
Hope that helps somewhat, maybe someone else will pipe in. <img src="gr_grin.gif" border="0">
Peace,
BadAss30th
