spohn drive shaft-leaking
Old Aug 13, 2005 | 05:25 AM
bernard shortt's Avatar
Default spohn drive shaft-leaking
started to the track and noticed that the driveshaft had trans fluid leaking out the end,,is said what the hech!!! so i pulled the drive shaft and spohn had put a vent hole in the middle of the drive shaft that goes in the tranny
how crazy!!!!! so i called and asked spohn about this and was told to go get it spot welded,,i asked them why do such a crazy thing the stock shaft doesn't have a hole,,,they said the company that fixes the shaft for them does that,,i told them what i thought about the hole and thanked them for the quick fix and 1 1/2 hrs of crawling in the grass,,beware if you buy a spohn shaft ,,might as well go get it welded first because it will leak a steady drip
