Installed 4.10s
Old Aug 15, 2005 | 08:38 AM
Vertigo's Avatar
Default Installed 4.10s
So I finally had my gears installed! I am 100% satisfied with these. Many people have mentioned on here that these gears should have come stock, I agree. I was worried that after the install I wouldn't be able to hook but that really isn't the case. I have Eagle F1's on the back 275/40/17 and I can break 1st loose if I try but I can go 7/8 throttle and dead hook in first it's quite nice! 1st runs out to 38mph, 2-60, 3-80, 4-112....Its like 1,2,3,4 are nuts, then you have 5th and 6th that are out there, however 5th pulls quite nicely at higher speeds. In 6th at 70 is around 1900rpm. I know my car pulls just as well as day 1, but I have adapted to its pull and am getting used to it. After 4.10 its damn right scary! Racing from a roll on the highway is crazy! Anyhow, if your considering this....do it as long as you don't plan on using ET streets or something crazy...be careful with the cappy 10bolt.
Old Aug 15, 2005 | 09:12 AM
MattIROC's Avatar
they're great
