posi vs. spool
Old Aug 31, 2005 | 11:56 AM
01bird58's Avatar
Default posi vs. spool
- i know just about nothing about a spool except its stonger than a posi, any input on how it works, price, pros/cons etc.... thanks
Old Aug 31, 2005 | 12:19 PM
spy2520's Avatar
spool = both axles locked, word is its good for straight lines, but bad for turning.
posi allows both wheels to spin at different speed but locks together going straight i think. Breakable.
Old Aug 31, 2005 | 02:16 PM
blue01ta's Avatar
spools aren't too bad for turning as long as it's not a tight turn. Posi's are usually quite a bit more money than a spool due to the simplicity of a spool and the complexity of a posi unit.
Old Sep 1, 2005 | 11:25 AM
01bird58's Avatar
perfect just what i was looking to know, thanks
Old Sep 1, 2005 | 09:20 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
If you get the spool and ever have to push the car around, be sure to get a buddy or two to help you. They're a bear to move ESPECIALLY if you're turning it. My Dad runs a spool in his '67 Camaro, so I know firsthand how difficult they are to move around.
Old Sep 15, 2005 | 07:24 PM
Wicked94Z's Avatar
i thought if you drove on the street long enough with a spool you'll eventually break it as both axles are locked and when you turn it puts a lot of stress on it... But i've never had one so don't listen to me!
Old Sep 15, 2005 | 08:16 PM
SUX2BU's Avatar
Nope i've been daily driving my spool for about 30k miles now and its great. yes when you turn it puts stress on the spool cause the tires are trying to turn at different speeds but the spool is ALOT stronger than the grip the tires have on the road. so instead of the spool getting damaged it just overcomes the grip of the tires and there fore you get tire chiping when you make a tight turn.
Old Sep 16, 2005 | 09:13 AM
Hawkcmc's Avatar
Why not just get a locker and have the best of both worlds?
CMC
Old Sep 16, 2005 | 09:29 AM
777's Avatar
777
They can sometimes get tricky on turns, especially in the rain (which is where you will notice it) They will lock up sometimes around a turn and you will have your hands full in the rain.
Old Sep 16, 2005 | 12:26 PM
SUX2BU's Avatar
Lockers still break. A spool is ALOT cheaper than any posi and you can rest asured it will never break. i didn't spend 2 grand on a rear end for it to break down the line.
Old Sep 16, 2005 | 12:35 PM
Vax's Avatar
Vax
yeah they still break.... If you don't match the rear to the horsepower, but then again, if you dump the clutch on a locker 12 bolt at 5500 rpm with an 700 hp car, you deserve to have a broken rear end. hehe
Old Sep 16, 2005 | 03:16 PM
Hawkcmc's Avatar
If this person is even questioning a posi in their rear i am sure they are nowhere near the power to break a locker. Ask Pro Stock John how his 31 spline locker is holding up in his 9 second car.
CMC
Old Sep 16, 2005 | 03:27 PM
2MuchRiceMakesMeSick's Avatar
Yep I agree with Juan. I streeted a spool with 9" in my old camaro. It wasnt bad at all. Best advice is to find someone in your area, go for a ride and you find out for yourself.
I like how when you go WOT on the road, the rear fish tailing was very managable. This was in a stalled auto with a trex also. Try that in a posi.
Old Sep 17, 2005 | 02:24 PM
Tranzor's Avatar
I went with a locker instead of a spool when I grenaded the Eaton posi in my 12 bolt. So far I'm happy with it... the locker and my McLeod Twin clutch and my 26" ET Streets are no longer enough tire to hold my car on a track launch, when I used to be able to launch it at 6k+. Now I gotta launch it around 4200 for it to find traction on the launch.
The locker isn't too bad to drive around on the street, thought it would be far worse than the Eaton was, and it isn't. Hardly noticeable really.
Old Sep 17, 2005 | 02:37 PM
TPY2KWS6's Avatar
True-trac = best of both worlds
Old Sep 17, 2005 | 04:50 PM
Hawkcmc's Avatar
Tru Trac still hasnt proven itself yet. Could be just as frail as any other posi for all we know. Locker is a proven design. It is not nearly as bad as most people think. I urge anyone looking to get a new diff to drive in a car with one.
CMC
Old Sep 21, 2005 | 02:50 PM
schultzsj's Avatar
I have been struggling with what kind of high-bias posi to get - I hate spinning only one tire!! I thought about a spool for about 2 seconds but I did not think they were really streetable.
You guys running spools - don't you have a serious push problem during high-speed/performance driving on dry pavement? If so, could I just run a stiffer rear sway bar to reduce it?
Thanks,
Steve
