Deep Transmission Pans
Old Feb 4, 2002 | 11:30 PM
Form4speed's Avatar
Default Deep Transmission Pans
I am going to be installing a yank torque convertor in my car soon, and was wondering if a deep transmission pan is worth the investment? BTW I am installing a transmission oil cooler also. Thanks in advance.
Old Feb 4, 2002 | 11:33 PM
JS's Avatar
JS
Default Re: Deep Transmission Pans
I bought the GM deep pan from Jay Fisher.
It hold alottle over a QT more and has a drain plug.I would get one...
JS
Old Feb 5, 2002 | 08:02 AM
SAINT WS6's Avatar
It's not going to make that much difference. I didn't bother because my transmission stays cool enough after the cooler. Put it this way, it will run slightly cooler, but it won't save something from breaking. I would save your money, but it's up to you. It can't hurt.
Old Feb 5, 2002 | 08:11 AM
NYNJRacer's Avatar
The benefits of the GM deep sump pan we offer are extra capacity and the ease of fluid changes though a factory drain plug. There are no real cooling benefits from the pan. Whether you get this deep sump pan, or the readily-available standard deep sump pan, with no drain plug, you have to get the matching filter, too.
Old Feb 5, 2002 | 10:20 AM
Chris Spiess's Avatar
I'm using Dearle pan with the cooling tubes. It also adds a bit of extra capacity. It also has some nasty dents in the bottom, but my car is lowered. It is not as deep as the GM deep pan.
Old Feb 6, 2002 | 12:14 AM
LT4vert's Avatar
I using the Dearle too . Very nice pan .
Old Feb 6, 2002 | 02:26 AM
AlonzoVersion 1.0's Avatar
Why not just get the b&m deep pan and have someone modify it with cooling fins?Basically drill some holes for the pipes to go through and make sure the holes are sealed.
Old Feb 6, 2002 | 10:05 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
[quote]Originally posted by The Booker Man:
<strong>Why not just get the b&m deep pan and have someone modify it with cooling fins?Basically drill some holes for the pipes to go through and make sure the holes are sealed.</strong><hr></blockquote>
The B & M already has cooling fins. When I changed convertors, and changed the tranny fluid, I think I had a total of ~12 total qts of fluid. PLUS, I have a tranny cooler up front in conjunction with the stock one. My tranny temps are ~180 when racing.
Tim
Old Feb 7, 2002 | 11:41 PM
schultzsj's Avatar
The cooler is far more effective than a deep pan with fins and has more than enough cooling capacity for the trans by itself. The deep pan that I saw the other day was $165 <img src="gr_eek2.gif" border="0"> - I say just put in the cooler and use the pan money for something else.
If you really want the drain plug (which is nice), I don't see why you could not just drill a hole in the pan, weld on a flange nut, and then put in your own plug - $10 max.
<img src="gr_stretch.gif" border="0"> Steve
Old Feb 8, 2002 | 11:35 AM
Originally posted by schultzsj:
<strong>The cooler is far more effective than a deep pan with fins and has more than enough cooling capacity for the trans by itself.</strong><hr></blockquote>
True, but some of us don't want to mess with running the lines and such. Personally, I'll do a cooler (and remote filter) when the trans comes out for a rebuild, but until then the dearale pan is better than nothing.
<strong> The deep pan that I saw the other day was $165</strong>
Must have been a cast unit, and yes they certainly are more exensive than I would consider. The stamped pans are much less expensive. The GM pan is relativly inexpensive and the Dearle pan is less than half that amount.
Old Feb 9, 2002 | 12:10 AM
schultzsj's Avatar
[quote]Originally posted by spiesscj:
<strong>
True, but some of us don't want to mess with running lines and such...</strong><hr></blockquote>
Yes, I would run a deep pan rather than nothing at all but he said he was putting in a cooler either way. A deep pan installed additional to a cooler is unnecessary and the money could be better spent elsewhere IMO.
Old Feb 9, 2002 | 12:52 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
B&M sells a drain plug kit. Plug, washers, nuts, the whole bit. $6.
Old Feb 10, 2002 | 11:43 AM
Gary98Z's Avatar
I used a deep trans pan for the Jimmy/Blazer. Got it for about $20 delivered from Gene at Phoneix (w/out filter) and so far it works like a charm.
