Long wheel bolt sizes?
I know that ARP makes a replacement metric stud you could use on the front (that has the same knurl as the stock studs), but I don't know if they're available in longer lengths than stock.
As far as the rear, what size holes are drilled in your axle flanges from Strange? They may have used a stock size hole (if so, see above), or bigger. Do you have studs installed in it now? Usually, you specify stud size when ordering the rear. It can be a PITA to have the flanges redrilled for different studs. I know there isn't really anyone around here that can do it right (I'm wanting to step up to 5/8 studs now, for more strength and to eliminate the shank style lug nuts).
Here's a pic of the rear ones using my stock rims
http://members.home.net/bob2of32/pic...wheelstuds.jpg
LAter <img src="gr_grin.gif" border="0">
