what's the difference in the 288 and 145 slaves?
Old Feb 11, 2002 | 08:34 AM
Smoke_ur_5.0's Avatar
Default what's the difference in the 288 and 145 slaves?
Is there a shim in one and not the other or what?
[ February 11, 2002: Message edited by: Smoke_ur_5.0 ]</p>
Old Feb 11, 2002 | 06:50 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: what's the difference in the 288 and 145 slaves?
Both have shims. From what I understand, the 145 slave has a thicker shim. Other than that, I believe they are identical.
Old Feb 11, 2002 | 09:22 PM
Viper's Avatar
If they are identical, why have different numbers? I'm going to buy a new clutch in a month and need a 2002 slave; which one do I order?
Old Feb 11, 2002 | 10:08 PM
Hawk's Avatar
145 is the new part. 288 was the replacement for the original slave that was trouble prone. 145 is the new design for the 2001's with the bigger displacement Master.
Old Feb 12, 2002 | 08:15 AM
ok that's what I figured. that the 145 has a thicker shim, right? Thanks fellas.
