prices?
Old Oct 10, 2005 | 10:41 PM
The95Firehawk#250man's Avatar
Default prices?
well i am having a stange sound come from the rear and i guessed the rear end(i heard it after i was spinning out alittle), about how much should it cost to get mine rebuilt? the macinhe shop that rebuilt my motor said 950-1050$$$$ is that right?? i would also like the 4.10 how would i go about that
Old Oct 11, 2005 | 06:22 AM
blue01ta's Avatar
If you have a 10 bolt you can usually pick a good used one up for between $300 and $400.
Old Oct 11, 2005 | 01:17 PM
Carter Hays's Avatar
What's wrong? What does the noise sound like? Open it up and look at it.
Don't take this the wrong way, I'm not trying to flame you this just a general observation. People swap cams, replace water pumps etc.. with no problem, but when comes to the rear-end they act like it's black magic and should never be touched by a mere mortal.
All your gonna need is a few "special" tools to overhaul it, if it needs it.
How can a "shop" say $950; $950 for what exactly
The live-axle is not cutting edge tech. If you have a driveway and some jack stands check it out If looks like something you don't want to mess with then go the salvage yard route it will be a hell of a lot less than $950
Old Oct 11, 2005 | 10:19 PM
chicane's Avatar
950-1050 is correct.... if you are replacing everything. And I mean everything.
But for just gears, bearings, axle bearings and tube seals.... I'd think more like 525-575.
Good shops will always quote "Worst case senario"... but also tell you that it would be in your best interest to come by for a test drive and possibly a quick inspection to get you closer to the real numbers.
