tcs/abs need help
Old Feb 13, 2002 | 08:05 PM
BLUEBALLS ZZ's Avatar
Default tcs/abs need help
ok. a frind of mine bought a strange 12bolt for his 2000 transam with only the top abs hook up on it and the orginal had the rings just on the side of each axle. so i wired it so it uses the one internal ring in the rearend. starting out with 4 wires i splicing the red wire "from left side ring sensor" and white wire "from the right side sensor" together and then the two balck wires together. then spiced that into the the abs sensor for the internal ring. now the abs keep comming on after a little bit of driveing. do i need to wire it different? is there anyway to fix this? besides getting rid of the abs. he don't care about traction control. thanks for your input.
Old Feb 13, 2002 | 10:32 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: tcs/abs need help
Have you checked to be sure that the wires are still spliced together? Mine didn't have a good connection the first try when my Strange 12-bolt was installed in my '98 T/A, and it would kick the "ABS INOP" and "BRAKE" lights on. I don't remember which wires we spliced together. That was close to two years ago. I'd recommend giving Strange a call. (847)869-7010
__________________
