Does your Strange 12 bolt leak
Old Oct 20, 2005 | 09:11 AM
HumpinSS's Avatar
Default Does your Strange 12 bolt leak
like a seive from the pinion seal. Ever since I bought my rear brand new the pinion seal has leaked. It has been replaced greased and re-installed and still leaks.
Old Oct 20, 2005 | 11:20 AM
chicane's Avatar
Find a auto parts supplier that carries 'Timken' seals. They are about $12.00. This is the only seal I use with the KTRE housings (which both Strange and Moser use). These housing are known for pin seal leaks........
Just make sure that the seal surface is spotlless (use brake cleaner) and use a quality sealant...... and then let it cure for about or at least an hour before driving.
Old Oct 20, 2005 | 12:43 PM
peterock98's Avatar
Mine leaked from the factory.It was replace 2 times and now it's good.
Old Oct 21, 2005 | 01:46 PM
weestro's Avatar
Yep, leaks here too. It seems sporadic tho and only a few drops. Is there a write-up anywhere for replacing the seal?
Old Oct 21, 2005 | 02:47 PM
Z95m6's Avatar
try getting a speedy sleeve.
Old Oct 21, 2005 | 03:52 PM
Ragtop 99's Avatar
mine leaked too. It took a couple tries and now it is fine. How old is yours? I think strange change the seal about 2 years ago to improve it.
Old Oct 21, 2005 | 04:18 PM
HumpinSS's Avatar
I used an install kit from jegs (ratech).
