Weight of stock a-arms (lower)
Old Feb 20, 2002 | 11:14 PM
AlonzoVersion 1.0's Avatar
Default Weight of stock a-arms (lower)
Anyone know of the weight of these bad boys?I am looking into lightning up the beast some more but dont know if I should spend the money on the aarms instead of something else unless there is a huge difference.
Old Feb 20, 2002 | 11:25 PM
Bob2of3's Avatar
Wheels up Director
Default Re: Weight of stock a-arms (lower)
I think there's a 6 to 7lbs saving going to Chrome moly lower A-arms. Probably the easiest money weight reduction item would be a lighter wheel/tire combo. If you do get the A-arms I'd suggest getting the K-member at the same time cause that alignment is gonna be an expensive bill to finish the install unless you have a hook up
Than you'll save between 44 to 50lbs off the front
LAter <img src="gr_grin.gif" border="0">
Old Feb 21, 2002 | 12:12 AM
Terry Burger's Avatar
I had my car aligned at mexicali-wheels for $25 after I got my kmember/aarms on. They didn't have a problem with it, just avoid the old white guys, they are the ones that will bitch.
MS Kmember saves 28#, MS aarms save 13#.
Old Feb 21, 2002 | 01:28 AM
Jason99T/A's Avatar
I can shift faster than you.
[quote]Originally posted by Terry Burger:
<strong>MS Kmember saves 28#, MS aarms save 13#.</strong><hr></blockquote>
Is this including removal of sway bar?
Old Feb 21, 2002 | 10:52 AM
Not including sway bar, which is another 8# I'd guess.
