Brake questions
Along the axis, then yes, something is wrong. Make sure the metal guides are in place.
There are 2 metal guides that set in the caliper/pad frame. The pads rest and ride on the guides, not the actual frame.
If they were not re-installed, then there could be some long-term issues.
If the play is in the clamping direction, then I really don't see it as an issue.
[ February 22, 2002: Message edited by: mitchntx ]</p>
