Paging Colonel... Transbrake ? inside
- Matt
I have tried a bigger battery, running through a relay, running bigger wires, and replacing the solenoid twice.
I still think it's just a lack of voltage. I talked with TCI and they said that the solenoid MUST see at the very least 12.5v to work. What I think is happening is that with a hot charged battery it is working for me and after the hot charge wears off the T-brake stops working. I have underdrive crank and alternator pulleys which aren't helping matters if this is the case.
This weekend I am going to put a nice hot charge on the battery beforehand and I'm going to take my generator and 40 AMP charger to the track with me. I'll try to keep a hot charge on the battery between runs and see if that fixes the problem.
Stay tuned and good luck with yours as well. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
