Bad driveshaft?
Old Nov 15, 2005 | 10:12 AM
mc01ta's Avatar
Default Bad driveshaft?
Got an 01 Trans Am M6 with the stock driveshaft. I was working under my car and decided to look at the driveshaft. With the tires chalked at the rear and the front and ramps (tires unable to turn or move) i could grab the driveshaft at the front and twist it about 1/2 an inch to an inch. I thougth there was supposed to be 0 play in the driveshaft. I have a vibration at 45 mph and around 70 and I be this is causing this. What do you all think? How should it be fixed, do I need a new driveshaft? Anything else I should buy if I need that? Thanks!
Old Nov 15, 2005 | 02:11 PM
CW00BlackTA's Avatar
It should move. The gears at both ends have play in them.
