u-joint needed
Old Nov 21, 2005 | 03:12 PM
BIRDONNOS's Avatar
Default u-joint needed
i just got a ford 9 inch with a 1330 yoke, i would like to keep this yoke. i am running a aluminum driveshaft with the stock u joints. i need to know which u joint i would need to go from the stock drive shaft to the 1330 yoke. i know the driveshaft needs the lock rings on the inside and i think the 1330 yoke needs the inside lock rings too because the 1330 has tabs on the outside of the yoke. thanks for your help
Old Nov 21, 2005 | 03:16 PM
chicane's Avatar
Your local NAPA will have the conversion u-joint that you need. They run about $20.00.
Old Nov 21, 2005 | 11:39 PM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
Spicer part number 5-212X works if you had your builder use a Ford motorsport pinion yoke.
