Driveline vibration. HELP! (long)
Old Feb 27, 2002 | 02:42 PM
FastMover's Avatar
Default Driveline vibration. HELP! (long)
I have a driveline vibration that is driving me insane. Let's start from the beginning. I have a 99 TA A4. For almost two years I ran a SY3500 with no problems. In November I installed a Thunder 224 cam and LS6 intake. With these new mods I felt that I needed a bigger harder hitting converter so I bought a TP4400. I installed the converter and immediatly noticed a driveline "shutter" at around 40-44 mph. I first thought that there was a problem with the converter so I called Mike and he suggested that I put a stock MAF on the car. I did and it did nothing to correct the problem. He also suggested that the torque arm might not be at the right angle. I had the angle checked and it was about 3 degrees off. In the mean time I switched over to a PI3200 due to driving the car for sales everyday. I then ordered the BMR adjustable torque arm. I installed the arm and had Mike Norris adjust it for me to -2. The shutter is still there. <img src="gr_images/icons/mad.gif" border="0"> I have had a 4-wheel alignment done, a wheel balancing, and I have tried a different driveshaft all with the same results. Shutter. <img src="gr_sad.gif" border="0">
This problem occurs when I let off the gas and the car is coasting at around 40-44mph. It feels as though something is tugging against the car. The car runs awsome and I hear no noise what so ever. I didn't think it was a problem with the tranny because it is more speed related than RPM related.
Anybody have any suggestions. Please...
Jim
<img src="images/icons/confused.gif" border="0"> <img src="gr_images/icons/mad.gif" border="0"> <img src="gr_sad.gif" border="0"> <img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" /> <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
Old Feb 27, 2002 | 05:05 PM
The Guy in MY 99TA's Avatar
Default Re: Driveline vibration. HELP! (long)
I am not sure what your problem could be but I have something of the same kind of problem..... When I go down the road I feel a vibration that seems to be comming from the tranny mount.... I looked at the mount and it seemed to be ok..... Im thinking that it could be the torque arm..... I'm going to order a new mount from Thunder Racing ,when I find my credit card, and put it on at school(im takin auto mechanics and we have a rack) and maybe try to tighten some of the bolts..... if this doesn't stop that problem I dont know what I'm going to do..... I am also going to change my U-joints... I think I might have discovered a new vibration this morning which feels like a tire...... I guess thats what I get for letting the car sit for 6 months without a transmission(you may slap me now)
Josh S.
Old Feb 28, 2002 | 11:16 AM
FastMover's Avatar
Anybody? Please...
Jim
Old Mar 1, 2002 | 09:09 AM
FastMover's Avatar
TTT
Old Mar 1, 2002 | 10:58 AM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I would have to say it's the adjustment of the Torque arm.I had mine set wrong when I first installed the TA and it did exactly like you describe. There has been quite a bit of question over the proper way to adjust.If the DS is +3 (that is 3 deg. front of the shaft pointing UP), the you need to subtract 2 degress from that and that is what your differential angle should be, which is +1. If you line them up in a straight line this will tell you if that is what's causing the vibration, but it won't help your traction until you bring the pinion angle down 2 degrees. Also , if you have a poly trans mount it will magnify any and all vibrations that you didn't know existed.It will rattle your teeth out.It's the price we pay for performance, Good luck.
Old Mar 3, 2002 | 06:24 PM
FastMover's Avatar
TTT
