Effects on systems of changing gearsets
'Want to know the Effect of Changing Gear Ratios? Look Here First!'
AND
'Rear End FAQ'
posted at the very top of this forum.
When you change gearsets you need nothing but the gears, a few bearings, and a few other inexpensive things covered at www.keliente.com/gears.htm
TCS/ABS is not involved when you are changing gears. There is a tone ring on the carrier, but it does not concern you, you just change the ring gear. The sensor is mounted in the housing and does not come out when you change gears.
You reflash the computer to correct the speedometer.
