TranGo shift kit, Need help
Old Mar 2, 2002 | 03:42 PM
MightyLS1's Avatar
Default TranGo shift kit, Need help
I just installed a TransGo shift kit in my 99 Z28,the problem is I only have Park and all the rest of the gears that I select make the car go forward, ie. R N OD D 2 1, I have followed the directions to the "T" and the vidio also. If anyone has any ideas what it might be I would love to hear it. <img src="graemlins/gr_cry.gif" border="0" alt="[whiner]" />
Old Mar 2, 2002 | 04:55 PM
AndUAndI's Avatar
Default Re: TranGo shift kit, Need help
I would pull it apart and make sure that you don't have any any holes blocked on the valve plate. I used 3 drill bits through the two gaskets and the plate in place while I bolted it up.
Also, re-check all valve solinoids to make sure that they are locked in place and all electrical connections are good.
If none of that works then I'd be on the phone to TransGo tech support first thing Monday. They're hard to get on the phone, but GREAT when you do.
Old Mar 4, 2002 | 02:00 PM
MightyLS1's Avatar
Well I ripped it back apart and the linkage to the valvebody popped off, now it works like it is suppose to. <img src="gr_grin.gif" border="0">
Old Mar 4, 2002 | 07:17 PM
AndUAndI's Avatar
My father always said look for the simple things. He was right.
I had problems with the shift linkage attachment too.
Have fun with your tranny.
