12 Bolt fluid amount?
Old Dec 15, 2005 | 03:32 PM
as35thss's Avatar
Default 12 Bolt fluid amount?
Hey guys. Just installed my 12 Moser rear. With upgraded cover. How much fluid does it take? Do you check at side plug or fill hole in cover?
Old Dec 15, 2005 | 06:35 PM
tillery's Avatar
I think around three and ahalf quarts. Both should be at the same level, the rear cover is usually easier to acsess. but on or cars the phb is in the way to fill and or check.
Old Dec 15, 2005 | 11:20 PM
bad6as's Avatar
it should drip out of the hole that you check the fluid level with
Old Dec 15, 2005 | 11:21 PM
bad6as's Avatar
well i guess you have an aftermarket cover so i would still use teh plug on the side of the rear and not on teh cover to be 100% sure. like he said im sure there around the same (fluid level)
Old Dec 16, 2005 | 04:11 AM
EPP's Avatar
EPP
3 qts. Bob
