Spool for a 7.5?
Old Dec 18, 2005 | 02:36 PM
SuperZ's Avatar
Default Spool for a 7.5?
I have herd from a few people that someone makes a spool for the stock 7.5inch 10 bolt.does anyone know where to find these?
Old Dec 18, 2005 | 02:43 PM
00tals1's Avatar
http://www.drivetrainspecialists.com...i-spool-1.html
Old Dec 19, 2005 | 12:29 AM
blue01ta's Avatar
BTW that's a mini spool. Nobody makes a full spool for the small 10 bolt.
Old Dec 19, 2005 | 01:52 AM
Hugger's Avatar
excuse my ignorance, what's the difference between a spool and a mini-spool?
Old Dec 19, 2005 | 02:32 AM
SuperZ's Avatar
I really would like to know also.If im not totally wrong here I think the mini spool has to be intalled into a open differential but I really dont know.Some one shime in
Old Dec 19, 2005 | 11:26 PM
00SS4780's Avatar
I think those mini spools are for a 26 spline axle.
Old Dec 20, 2005 | 08:00 AM
Hawkcmc's Avatar
Mini spool is installed in an open differential case while the full spool replaces the differential entirely. The Mini spool is not a good idea on the street, they are made more for dirt track racing. They tend to break down and I have heard of them exploding out the back of diff covers.
CMC
Old Dec 22, 2005 | 03:47 PM
d james's Avatar
I had a mini spool in a 8.5 inch ring 4.10 gear that was powered by a big block 455 buick-not stock either. It held up just fine, but thats a different rear end of course. I had to drive slowly around corners or else the tires would bark since they don't unlock, still they weren't to bad on the street. I even drove that thing through the winter. They are pretty cheap so if you blow one, your not out alot of money, unless you destroy the rear
