Drive shaft length
Old Dec 28, 2005 | 03:21 AM
Frans96SS's Avatar
Default Drive shaft length
will the stock drive shaft work after goin from a 6 speed and a 10 bolt to a 6 speed and a 9 inch?.... or will a shorter one be needed?
Old Dec 28, 2005 | 12:08 PM
Frans96SS's Avatar
noone?
Old Dec 28, 2005 | 12:52 PM
DanZ28's Avatar
A stock length DS should work. I probably would not use a stock DS though, at this point, it will be your weak link.
If you can, check fit the stocker to make sure it fit's and order one up. If you use Denny's, they custom make it for you using your measurements anyway.
Dan
Old Dec 28, 2005 | 01:07 PM
Frans96SS's Avatar
Dan
yeah its for a customer car its in the body shop and it needed a rear so there just putting this in so he can bring it to my shop .... we are gonna do an after market one....
