ABS/TCS Rings on 9"
Old Dec 31, 2005 | 12:23 PM
Smartass6885's Avatar
Default ABS/TCS Rings on 9"
Can i use the ABS/TCS Rings off of my stock 10 bolt on a 9" rear. The rear will be coming from billingsley.
thanks
Old Dec 31, 2005 | 01:36 PM
86irocz's Avatar
Just specify that you want the axles made to accept your stock rings.
Old Dec 31, 2005 | 02:11 PM
J&J Speed Shop's Avatar
Best bet is to call Billingsley. I know with Moser you have to order the axles for the TCS option then you just press them off the stockers and onto your new ones
Old Dec 31, 2005 | 04:10 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
yes you can use them but you have to tell them that your going to use that setup.
Old Jan 2, 2006 | 09:30 PM
Thank guys.
