Someone please help!!
Old Mar 8, 2002 | 11:02 PM
99taws6's Avatar
Default Someone please help!!
I need help with my clutch problems. I have a 1999 Trans Am that I recently put a 2002 ZO6 clutch in. I upgraded the slave and have a stock master.
The car is hard to shift now. The shifter used to go into gear so easy and now it just seems to take a whole lot of pressure and at high RPM's forget it. The clutch engages right off the floor, but it does not fully engage until almost the top.
Do you think the drill mod or adjustable master mod would be the best? Your suggestions are needed as this is making driving non enjoyable.....
George
Old Mar 10, 2002 | 09:27 AM
2000 Camaro SS's Avatar
Default Re: Someone please help!!
This sound familiar I've read it before and the way to fix it was the drill mod. Seems there is not enough fluid passing through the line fast enough.
Old Mar 10, 2002 | 09:29 AM
99taws6's Avatar
That is what I was thinking, but it seems that people are doing the drill mod for all types of problems, I am gonna do it, I hope it helps...
What do you think is causing the hard shifting? Would the adjustable master help this?
