what rust preventative did you use?
Old Jan 8, 2006 | 08:40 PM
ninobrn99's Avatar
Default what rust preventative did you use?
As the title says, what rust preventative did you use on your 12 bolt or 9" housing and where did you get it??
Old Jan 8, 2006 | 09:08 PM
BigKap94z's Avatar
I just cleaned up the housing and primed it, then sprayed it and followed that up with some clear coat. i probably would have used POR-15 if i hadn't left my can unsealed accidently causing it to harden up.
Old Jan 9, 2006 | 06:02 PM
ninobrn99's Avatar
will this be what i need??
http://www.por15.com/PRODUCTS/PRIMER...4/Default.aspx
Old Jan 9, 2006 | 06:06 PM
ninobrn99's Avatar
or how about a quart of this one?
http://www.por15.com/PRODUCTS/PRIMER...8/Default.aspx
Old Jan 10, 2006 | 08:24 AM
weestro's Avatar
POR-15 no doubt! All you need is the starter kit to paint the 12-bolt and you will have some left over afterwards. Amazing stuff that will keep the rear looking new forever probably.
http://www.por15.com/PRODUCTS/PRIMER...7/Default.aspx
